  • alicanteman Friend
    #132878
    hi,
    i am using the latest joomla release 1.5.6 with template ja rochea.
    when i first attempted to install the template i got an error message “There was an error uploading this file to the server” i then change the php.ini file to increase the max uplaod file size to 8 mb but now am getting an error message “Unable to write entry”
    Any ideas?
    Richard
    #268448
    Do you try with others template ?
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 16 years, 2 months ago.
