  • alicebb Friend
    #141724
    I downloaded the JA Olyra template file but kept getting an error when trying to install it that the file ja.transmenu.css could not be found. I looked in the zip file & that file is indeed missing as it has been renamed to ja.transmenuh.css for some reason.
    I downloaded the files again on several different machines both Mac & Windows & unzipped them on several different machines both Mac & Windows & the file is wrongly named in all of the downloads.
    Anonymous Moderator
    #307224
    It is very strangle.
    Please kindly download this file and extract, copy ja.transmenuh.css file to templates/ja_olyra/ja_menus/ja_transmenu folder.
    1. ja.transmenuh.zip
    alicebb Friend
    #307226
    <em>@JA Developer 131859 wrote:</em><blockquote>Hi
    Please kindly download this file and extract, copy ja.transmenuh.css file to templates/ja_olyra/ja_menus/ja_transmenu folder.</blockquote>That is not the problem. I have the file ja.transmenuh.css The problem is that in templateDetails.xml this is not the file referenced:-
    <filename>ja_menus/ja_transmenu/ja.transmenu.css</filename>
    I renamed ja_transmenu/ja.transmenuh.css to ja_transmenu/ja.transmenu.css & then the installation was OK.
    Is the problem that the XML file is wrong or that the filename is wrong?
    Anonymous Moderator
    #316613
    Hi alicebb
    It is correct: I renamed ja_transmenu/ja.transmenuh.css to ja_transmenu/ja.transmenu.css & then the installation was OK.
This topic contains 4 replies, has 2 voices, and was last updated by Anonymous 15 years, 3 months ago.
