  • lucky93 Friend
    #153572
    Error message “500 Internal Server Error” when install Quickstart JB1.4.7 on my computer.
    It’s not possible use Quickstart to start installation.
    I have NO problem to install Quickstart 1.4.5 and Quickstart 1.4.6
    Problem only happen to Quickstart 1.4.7
    Anonymous Moderator
    #353160
    I would like to let you know that we are investigating your issue. Please keep on hold and I will inform you right after getting more information.
    Really appreciate your patience.
    Anonymous Moderator
    #353248
    <em>@lucky93 190491 wrote:</em><blockquote>Error message “500 Internal Server Error” when install Quickstart JB1.4.7 on my computer.
    Problem only happen to Quickstart 1.4.7</blockquote>
    The error might be caused by your server configurations. Please try again with localhost installation to figure out first.
    lucky93 Friend
    #353259
    I have mentioned the installation is on ” my computer localhost “.
    The strange thing is NO problem to install Quickstart 1.4.5 and 1.4.6
    ovidius Friend
    #353261
    do you use windows ? cause that can be a problem i think..
    lucky93 Friend
    #353262
    My PC OS is Vista
    I don’t get why 1.4.5 and 1.4.6 are OK but 1.4.7 not ok
    This is why I start to think about if something wrong with 1.4.7 Quickstart package
    ovidius Friend
    #353264
    what service u use for web? xampp ? or apache + php ?
    lucky93 Friend
    #353267
    The installation is on my “PC” localhost for test purpose
    ovidius Friend
    #353269
    aha .. why u dont use a free hosting service for testing? its more better
    ovidius Friend
    #353270
    i can help you to find a free hosting services..
    lucky93 Friend
    #353271
    I have running JB1.4.7 website already.
    Just like to setup a test site on my PC to do all kind of test.
    I knew where to find the free hosting service, thank you
    ovidius Friend
    #353272
    OK , have a nice day ..
    lucky93 Friend
    #353344
    Problem solved
    I found one HTACCESS file ( .htaccess ) on JB1.4.7 Quickstart->ja_jobboard
    Remove this file then installation can be completed.
This topic contains 13 replies, has 3 voices, and was last updated by  lucky93 14 years, 4 months ago.
