November 29, 2013 at 10:20 am #192636
hi guys,
when I finished installation the JA brisk with the quickstart package for Joomla 3.0.
My web come with the following warning message, what’s taht mean ?
“Warning
JFolder::create: Could not create directoryPath: /webhome/h258409/web/www/images/resized/
JFolder::create: Could not create directoryPath: /webhome/h258409/web/www/images/resized/”
Thanks for any help!
November 29, 2013 at 10:29 am #513928Hi
You have all your system folders unwritables
to check go to system — System Information — Directory Permissions
All folders needs to have 755 as chmod settings
November 30, 2013 at 2:39 am #513974All folders do have 755 as chmod settings,but I have no idea why the system info show them “unwritable”.
What’s the right stus? those system folders should be ” writable”?
Thanks in advance!
<em>@pavit 400042 wrote:</em><blockquote>Hi
All folders needs to have 755 as chmod settings</blockquote>
November 30, 2013 at 7:59 am #513978Hi
<blockquote>What’s the right stus? those system folders should be ” writable”?</blockquote>
Yes
Expecially the logs and tmp folder
December 7, 2013 at 9:38 am #514641it may works when I change chmod settings to 777, but another problem comes out.
It show ” 502 bad gateway ” errors info when I am installing the ecommerce componts- joomshopping ,
what can I do ?
December 7, 2013 at 9:51 am #514642I cannot see Joomshopping component installed on your website .
phong nam Friend
phong nam
- May 2015
- 974 times in 888 posts
December 9, 2013 at 4:39 pm #514816Hi ottawa,
For this 502 bad gateway error, It will be great when you can raise a question on JoomShopping forum so that this commercial component developers and other experienced users can give you better suggestion in this case.
This topic contains 7 replies, has 3 voices, and was last updated by phong nam 11 years, 1 month ago.
