  • moyousuf Friend
    #171595
    Hi everyone,
    I tried How To Perform A QUICKSTART Installation – A STEP-BY-STEP GUIDE on my local PC and it worked fine with Community Plus. But when i tried same technique to install on my webhost it could not.
    after hours of work i have this error when i try to browse my site.
    Database Error: Unable to connect to the database:Could not connect to MySQL
    Can anyone help me please? is there any step by step guide for installing on webhost?
    Your help is highly appreciated.
    moyousuf Friend
    #428637
    to make a bit clear about this issue
    I installed joomla 1.5 using fantastico on my webhost
    then Installed a template from joomlart using quickstart package of that template
    when i faced problem installing with quickstart, i moved customised template from my Local PC to webhost using Filezilla. Now customised template is in my subdomain. but when i try to browse the site i get this error.
    when i try to load http://ecommerce.inewconcept.com/assalaam i have this error:-
    “Database Error: Unable to connect to the database:Could not connect to MySQL”
    jooservices Friend
    #428657
    Please update configuration.php file with your new database information.
    Because you moved from your localhost to webshot. So you need update your database access information.
    Thank you
    ps:// i think you also need restore your database too.
    moyousuf Friend
    #428675
    thanks jooservices,
    Can you show me what parameters i have to modify? however i deleted all those files and uploaded quickstart pack on my webhost and tried to install from quickstart, but im struck there in my 5th step. here i have attached all screenshots. can you help me please?
    For your info: I have created Database, username and pwd respectively. and entered there accordingly.
    thanks a lot in advance
    1. joomla-step1
    2. joomla-step2
    3. joomla-step3
    4. joomla-step4
    5. joomla-step5
    jooservices Friend
    #428676
    Please make sure you have entered valid value for database access ?
    I have bit worries you have entered invalid value. Please check it w/ your hosting provider.
    Thank you,
    moyousuf Friend
    #428679
    thanks for your instant reply.
    Yes i entered all values exactly just as i created the database, user details.
    jooservices Friend
    #428693
    Please update me w/ your cpanel access. I’ll try to help you install a quickstart.
    Thank you,
    moyousuf Friend
    #428894
    Thanks jooservices for all your effort to solve this problem. Support staff from the host said i have to add prefix to database and user and it worked fine. Thanks a lot for your replies.
This topic contains 8 replies, has 2 voices, and was last updated by  moyousuf 13 years, 1 month ago.
