  • gandaogo Friend
    #160037
    when i try to install teline IV with quick install i obtain this error: Proble with sample_data.sql
    HELP
    Erreur
    Des erreurs sont survenues lors du remplissage la base de donnĂ©es: Table ‘fasoactu._weblinks’ doesn’t exist SQL=INSERT INTO `_weblinks` (`id`, `catid`, `sid`, `title`, `alias`, `url`, `description`, `date`, `hits`, `state`, `checked_out`, `checked_out_time`, `ordering`, `archived`, `approved`, `access`, `params`, `language`, `created`, `created_by`, `created_by_alias`, `modified`, `modified_by`, `metakey`, `metadesc`, `metadata`, `featured`, `xreference`, `publish_up`, `publish_down`) VALUES (1, 32, 0, ‘Joomla!’, ‘joomla’, ‘http://www.joomla.org’, ‘
    Home of Joomla!
    ‘, ‘0000-00-00 00:00:00’, 3, 1, 0, ‘0000-00-00 00:00:00’, 1, 0, 1, 1, ‘{“target”:”0″,”count_clicks”:””}’, ‘en-GB’, ‘2005-02-14 15:19:02’, 0, ”, ‘2010-07-10 23:41:06’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (2, 33, 0, ‘php.net’, ‘php’, ‘http://www.php.net’, ‘
    thangnn1510 Friend
    #376319
    Dear Gandaodo!
    Please delete all your code and data in database then install again. You should change the prefix for tables in database:
    “fasoactu._” to other.
    Regards!
    zen1 Friend
    #383440
    To properly install Joomla! and extensions should be in *. sql to change the entry: TYPE = MyISAM on ENGINE = MyISAM.
This topic contains 3 replies, has 3 voices, and was last updated by  zen1 13 years, 9 months ago.
