  • mongini Friend
    #133459
    I install Ja iris quickstar joomla 1.5 in http://www.lamardeventos.com, doesn´t work ok. I only have this message “Parse error: syntax error, unexpected T_STRING in /home/lamarde/public_html/templates/ja_iris/html/mod_login/default.php on line 11”
    #271310
    Hi mongini !
    have you solved the problem ? i have checked your site but couldn’t see problem,
    mongini Friend
    #271599
    I downgrade the site to Joomla 1.0, every thing ok in this version.
    Thaks
    craigst Friend
    #271604
    I just did a fresh install just now and went to the “preview” and got this same message:
    Parse error: syntax error, unexpected T_STRING in /homepages/0/d228871717/htdocs/changeimpetus/newsite/templates/ja_iris/html/mod_login/default.php on line 11 Site is http://www.changeimpetus.com/newsite
    I don’t want to use Joomla 1.0 if I don’t have to..I used the quickinstall zip as well.
    Craig
    liotru Friend
    #273449
    I have the same problem
    thanks for help
    craigst Friend
    #273465
    I did not get a resolution to this problem for Iris Template- I installed a new template and it works.
    Must be a template problem then??
    I need to use this Iris template for a new demo site, so it would be good to get this resolved guys.
    Menalto Friend
    #273469
    Try to remove the mod_login folder from the html folder of the template.
    ja-iris/html/mod_login folder
    #273541
    please edit default.php(templatesja_irishtmlmod_login folder)
    please change
    <?php/*------------------------------------------------------------------------
    # $JA#PRODUCT_NAME$ - Version $JA#VERSION$ - Licence Owner $JA#OWNER$
    # Copyright (C) 2004-2008 J.O.O.M Solutions Co., Ltd. All Rights Reserved.
    # @license - Copyrighted Commercial Software
    # Author: J.O.O.M Solutions Co., Ltd
    # Websites: http://www.joomlart.com - http://www.joomlancers.com
    # This file may not be redistributed in whole or significant part.
    to
    <?php
    That is bug, i will update
    mj1256 Friend
    #273671
    looks more like a typo than a bug 🙁
This topic contains 9 replies, has 6 voices, and was last updated by  mj1256 16 years, 2 months ago.
