  • lwdlinda Friend
    #1016276
    Hello Im trying to install Ja Alumni (quickstart) but in the final step, when the installation starts, it jumps back to step 3 again. No error messages or anything. Am I doing something wrong?
    Thanks in advance!
    Pankaj Sharma Moderator
    #1016288
    I just download the quickstart package and installed it with sample data. Installation done without any issue. http://prntscr.com/ehfhbb http://prntscr.com/ehfhmd
    Kindly try this:
    1. Delete the current files and database that you used for the installation.
    2. Increase the Max execution time and memory limits from PHP configuration of your server
    3. Restart Apache to load the new values.
    4. Now download and install the latest downloaded package on fresh DB.
    5. Hope it helps.
    lwdlinda Friend
    #1017139
    I’m not very technical and I am unable to carry out step 2 and 3.
    I have been in contact with my hosting company, but they canĀ“t help me either.
    Thanks for your reply and support anyway!!
    hilmarg Friend
    #1017345
    I have a similar problem. When I try in install the quickstart package (ja-alumni.zip) it eventually comes back with the warning:
    JInstaller: :Install: Can’t find Joomla XML setup file.
    The Joomla package cannot be installed through the Extension Manager. Please use the Joomla! Update component to update Joomla.
    I have updated php.ini upload_max_filesize and post_max_size to 50M.
    I have the same problem with the Biz quickstart package. Installing individual extensions works fine. This is a fresh Joomla installation (v3.6.5).
    #1017350
    Hi @hilmarg
    Quickstart is standalone package and not install on Joomla. You have to install it separately like Joomla installation. Also, i request you to open thread on Correct forum page.
    #1017354
    lwdlinda Friend
    #1017377
    #1017503
    I need Cpanel details to check your PHP configurations and for new DB and package.
    Kindly send it via Private reply.
    lwdlinda Friend
    #1017665
    #1017755
    I have no access to create DB with above details.
    Can u please share cpanel login so i can help you in installation process.
    lwdlinda Friend
    #1017760
    #1017898
    Please let me know with details if you still wish to use the same template because it can be issue from server side that i can check via your Cpanel.
This topic contains 11 replies, has 3 voices, and was last updated by  Pankaj Sharma 7 years, 8 months ago.
