April 7, 2015 at 11:23 am #205355
I tried to install the template on both my live site and my dev site but I can’t install the component com_jaextmanager.v2.5.8 and quickstart jatc_wall_j33.
Can you please help ? I need to make some test on my dev before. I really love this template and need it to work.
You can check on both sites I provided you the links.
Thanks a lot and have a great day !
Saguaros ModeratorSaguaros
April 8, 2015 at 4:02 am #566265Hi
This is a known issue when Joomla 3.4.0 comes out: https://docs.joomla.org/J3.x:Extension_won't_install
The temporary solution is that you unzip the package of extension you want to install to a folder, then zip again this folder and install via Extension manager.
I just proceed the same steps and install JAEM extension into your dev site. You can do the same to your live site.
WIth the quickstart package, the installation will be the same as you install a Joomla package, you can’t install it via Backend > Extension manager. Pls check out this guide for more info: http://www.joomlart.com/documentation/other/quickstart-installation
April 9, 2015 at 4:38 pm #566495I did what you said with the jatc_wall_j33 and I still have the error
Error on updating manifest cache: (type, element, folder, client) = (library, phpmailer, phpmailer, 0)
Error on updating manifest cache: (type, element, folder, client) = (module, mod_stats, mod_stats, 0)
Error on updating manifest cache: (type, element, folder, client) = (module, mod_status, mod_status, 1)I tried to update to 3.4 but it doesn’t want to do it too…
Thanks for your help
April 9, 2015 at 4:46 pm #566496I checked the patch but i never player with those things…
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
April 9, 2015 at 4:49 pm #566497<em>@lili_000 467477 wrote:</em><blockquote>Hi,
Thanks a lot and have a great day !</blockquote>
Hi there
# Please make sure you are not install quickstart on exists site. Quickstart only use for fresh site with sample database.
# I have checked your backend and see you are using Joomla! 3.4.0.
Please upgrade it first at
https://www.onmagasine.ca/administrator/index.php?option=com_joomlaupdate
I have just helped you to do that.
Now your site updated to Joomla! 3.4.1Now try to install JA Wall template
http://www.joomlart.com/forums/downloads.php?do=file&id=3012
Look like you already have existed.
Thank you,
Viet VuApril 9, 2015 at 5:08 pm #566500I am working on the dev site not the live one
April 9, 2015 at 5:14 pm #566501I send you a private message 🙂
April 9, 2015 at 5:24 pm #566502I don’t know what you dit but part of my live site is screwed up…
April 9, 2015 at 5:28 pm #566503That’s why I always test on my dev first not the live site… Please respond because my main component is screwed up
April 9, 2015 at 5:35 pm #566504Anyone ? It is still 13h35 I have plenty of stuff to do
April 9, 2015 at 5:49 pm #566506I have someone restauring my site before the problem… Please don’t touch anything
April 10, 2015 at 2:19 am #566526I reinstalled my backup and will work on it.
Thank you you can close this.
- October 2014
April 10, 2015 at 3:53 am #566538Woh
Glad to hear thatThank you,
Viet Vu -
This topic contains 14 replies, has 3 voices, and was last updated by lili_000 9 years, 7 months ago.
