  • moyousuf Friend
    #176572
    Installing K2 component stops JA newsticker animation, Flash action script animation or any script based animations such as photosliders.
    I tried to uninstall K2 then all above said animation works fine. reinstalling K2 again makes same problem.
    What is the solution Please?
    Your help is highly appreciatted.
    HeR0 Friend
    #450953
    I think that you have same problem as topic http://www.joomlart.com/forums/topic/mainmenu-and-k2-modules/
    If after re-config K2 setting, your issue still exist, let’s me know 🙂
This topic contains 2 replies, has 2 voices, and was last updated by  HeR0 12 years, 8 months ago.
