  • sbaldwin Friend
    #161583
    Hi, I would like to install a Photo Gallery module.The Photo Gallery module won’t fit in the Left or Right module position. I would like to install the module into the “Main Body” position. Is that possible? The main body is the only section with enough room to display the photos but I cannot see a position for Main Body. It is listed as a module position in the instructions.Thanks!
    aman204 Friend
    #381904
    You can go on to load module in main body area using this plugin::
    http://extensions.joomla.org/extensions/core-enhancements/embed-a-include/6958
This topic contains 2 replies, has 2 voices, and was last updated by  aman204 13 years, 9 months ago.
