  • 261284 Friend
    #191364
    Hello Sir
    I wish to know if its possible to integrate Disqus Comment System with JA FUBIX template. If yes how do we proceed and how to disable the k2 comment system currently enable by default.
    And lastly how do we tweak the comment counter for it to display that of disqus.
    Thank you in advance.
    HI
    You can add to the template the JA DIsqus Debate Plugin and disable the actual settings for comments using the K2 settings
    after installed the plugin Ja Disqus DEbate you will need to setup a new account on the disqus.com website from where you can manage all your comments on the website.
    261284 Friend
    #508921
    Thanks works for me.
This topic contains 3 replies, has 2 voices, and was last updated by  261284 11 years, 1 month ago.
