bohemiadesign Friend
bohemiadesign
- March 2010
April 28, 2010 at 10:52 am #150700Hi,
Please see this link http://www.bohemiadesign.com.au/logicamms/index.php?option=com_content&view=article&id=125&Itemid=79 I have to modules published in the left column and they are actually overlapping each other.
I have done this change to the layout.css file http://www.joomlart.com/forums/topic/how-to-make-left-body-right/
If anyone have any suggestion please let me know.Thanks,
JonasAnonymous ModeratorJA Developer
- 2008 times in 1700 posts
May 2, 2010 at 4:45 pm #342393Hi you
Open template.css file, at about line 1085, find following code section:
.ja-inset2 div.ja-moduletable, .ja-inset2 div.moduletable {
margin:0 8px;
}and change to:
margin:0 8px;
float: left;
}bohemiadesign Friendbohemiadesign
- March 2010
May 2, 2010 at 11:42 pm #342437Hi,
Thanks for your reply. This only partly fixed teh problem. Pleae see attached screen shots of the left column for IE7 and IE8. Somthing happens to the background of the module.Thanks again,
jonas
Anonymous Moderator
JA Developer
May 5, 2010 at 5:22 pm #342736Hi bohemiadesign
I don’t find this issue in Ie7 and Ie8. It looks fine for me
Please try to delete the cache of browser and check again
- March 2010
May 5, 2010 at 8:15 pm #342751Hi,
It looks good in IE 8. The issue only seems to appear in IE 7.
I have had 3 other people experiencing the same problem as me.
Please see below my screen dump.Kind Regards,
Jonas
- March 2010
May 6, 2010 at 9:17 am #342805Hi,
I actually have the same problem here as well when using Category/Blog layout.
http://www.bohemiadesign.com.au/logicamms/index.php?option=com_content&view=category&layout=blog&id=54&Itemid=160
Thanks,
JAnonymous ModeratorJA Developer
May 7, 2010 at 4:42 pm #342940bohemiadesign Friendbohemiadesign
- March 2010
May 10, 2010 at 11:37 am #343132Thanks,
I had an accordion menu (module) installed. It seems that the accordion menu was the cause for the left column to play up.
But I still have a problem with my Category/blog layout http://www.bohemiadesign.com.au/logicamms/index.php?option=com_content&view=category&layout=blog&id=54&Itemid=160
When the read more is next to the image and you hover over it – it makes the lines underneath jumpThanks
Jonas
Sherlock FriendSherlock
- 2478 times in 2162 posts
May 24, 2010 at 8:37 am #344525Dear bohemiadesign
I just checked on the url http://www.bohemiadesign.com.au/logi…=54&Itemid=160 but maybe now you have remove this category.
- March 2010
May 24, 2010 at 9:16 am #344534It was the accordian menu that made my column display differently.
After I removed the accordian module it was OKJonas
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 3 voices, and was last updated by bohemiadesign 14 years, 5 months ago.
