abdullah canipek Friend
abdullah canipek
- November 2014
February 27, 2016 at 11:45 am #891357Hi there again,
I modified css files (template.css) what my customer requests. I worked firtsly home page and design is ok that we want.
But some menu items are not working correctly. There is top margin some menu items. Probably template styles cause this issue but all of them use same template.css file, why different in others the right one (for example home page is true).
I can not fix this problem.
Please help me.
Saguaros ModeratorSaguaros
February 29, 2016 at 2:27 am #892096Hi
You can send me screenshot highlight the issue and how you want it should be, it seems to be fine as I can see.
abdullah canipek Friendabdullah canipek
- November 2014
February 29, 2016 at 7:32 am #892152Hi, there are screenshoots for explain my issue. So i want to position menu items on slider image like JA Events II.
I did fix this but i can not this white blank area.
February 29, 2016 at 8:20 am #892172Could you try to clean browser’s cache & cookies? because as I can see it’s different from your screenshots: http://prntscr.com/a9bak3
- November 2014
February 29, 2016 at 8:30 am #892176Yes i try to clean cache. Even i try with another pc that never visit this site.
Please could you test the other pages. (Hakkımızda, Video, Galeri, Faaliyetlerimiz,..) because main page is fine, the other pages have problem 🙁
And thank you for your help.
February 29, 2016 at 9:41 am #892219You can try with this tweak:
Go to file: ROOT/templates/ja_charity (your default template)/css/custom.css (create this file if it doesn’t exist)
- Add this css rule:
.owl-carousel .owl-wrapper-outer { display: inline-block; margin-top: -100px; overflow: hidden; position: relative; width: 100%; } .home .section-inner {margin: 0;}
- November 2014
February 29, 2016 at 10:13 am #892262I add this file and codes, and i clean cache and problem is continue.
Mozilla view is very bad.Saguaros ModeratorSaguaros
February 29, 2016 at 10:15 am #892265You can send me the Admin & FTP account of site you’re working via Private reply, I will have a look.
- November 2014
February 29, 2016 at 12:28 pm #892316This reply has been marked as private.Saguaros ModeratorSaguaros
March 1, 2016 at 8:30 am #892769You will need to update additional style for masthead module. Here is the full style I just updated into ‘custom.css’ file:
.owl-carousel .owl-wrapper-outer { display: inline-block !important; margin-top: -100px !important; overflow: hidden !important; position: relative !important; width: 100% !important; } .home .section-inner { margin: 0 !important; } .t3-masthead .jamasshead { display: inline-block; margin-top: -100px !important; position: relative; width: 100%; }
- November 2014
Viewing 12 posts - 1 through 12 (of 12 total)This topic contains 11 replies, has 2 voices, and was last updated by Saguaros 8 years, 10 months ago.
