  • bollanga Friend
    #179882
    I am using the JA social plugin to retrieve content from youtube. When presented in the wall. it seems like the Introtext word limit does not work with k2 documents. Is there something I am missing or Introtext word limit does not work with k2 articles and JA social plugin ? Any help is greatly welcomed
    Hi bollanga,
    May I know where did you change the introtext word limit number? You should change in K2 category settings like in demo site, there is K2 menu item named JoomlArt, so you will go to this K2 category and change number of word limit: http://easycaptures.com/fs/uploaded/626/6308253050.png.
    Then clean the cache, by default, the system cache is still enabled, if you’re in developement stage, please disable it so that you can see the changes immediately.
    Regards.
    arucardx Friend
    #464055
    This is a known K2 problem. Ran into this problem today while working on the site so here’s the solution.
    http://getk2.org/community/New-to-K2-Ask-here-first/13197-IntroText-words-limit-not-working-while-selecting
    Note that there are about 3 ways to fix it in that thread. Just use one.
This topic contains 3 replies, has 3 voices, and was last updated by  arucardx 12 years, 5 months ago.
