brucetaylor Friend
brucetaylor
- May 2008
- 2 times in 1 posts
September 21, 2008 at 11:21 am #133660I have tried this on a freash J1.5.7 install, if I publish a module to the left and to the right the layout is fine. But if you stop publishing the menu on the left on page then the module on the right moves to the left –
This is with both modules –
This is with the same right module but no left menu –
brucetaylor Friendbrucetaylor
- May 2008
September 23, 2008 at 3:36 pm #271912Can anyone help with this? It one of the very last things I have to sort out with the template
Sherlock FriendSherlock
- 2478 times in 2162 posts
September 24, 2008 at 1:59 am #272002Hi brucetaylor !
Please send url of your site !brucetaylor Friendbrucetaylor
- May 2008
September 24, 2008 at 6:36 am #272060Hi,
The site is at http://www.designandbuild.org
I am also looking to increase the size of user 7, so I can publish ja slideshow to it. any suggestsions where the code is ?
September 29, 2008 at 9:30 am #273021Hi brucetaylor !
I have checked your site , go to Conservatories menu , but can’t see the problem .brucetaylor Friendbrucetaylor
- May 2008
September 29, 2008 at 9:34 am #273022Try the contact us page, I had had to publish both left and right on the main part of the site because it is live.
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
September 29, 2008 at 9:45 am #273024Just a shoot here:
find this in the css file:
#ja-containerwrap-c #ja-col1, #ja-containerwrap-c #ja-col2 {
width:100%;
Change it to this here:
#ja-containerwrap-c #ja-col1 {
width:100%;
width:24%;
}Menalto FriendMenalto
- May 2007
September 29, 2008 at 9:46 am #273025Just a shoot here:
find this in the css file:#ja-containerwrap-c #ja-col1, #ja-containerwrap-c #ja-col2 {
width:100%;
}Change it to this here:
width:100%;
width:24%;
}1 user says Thank You to Menalto for this useful post
- May 2008
September 29, 2008 at 9:53 am #273026Fixed !!! 🙂
- May 2008
September 29, 2008 at 9:56 am #273028Doh, spoke to soon
If you do it the other way round and only publish to the left. It gets all confused again. I have swapped the layout around in the conatct us page
The menu is publsihed to the left
- May 2007
September 29, 2008 at 10:00 am #273030Hmmm, then it must be something with this image here:
#ja-containerwrap-c #ja-container-inner {
background:url(../images/vdot2.gif) repeat-y 78% 0;
If its set to 23% instead of 78% it will show up in right place. but not sure how that is on other pages…..brucetaylor Friendbrucetaylor
- May 2008
September 29, 2008 at 10:01 am #273031I have changed it to
[PHP]#ja-containerwrap-c #ja-col1 {
width:24%;
width:24%;
}[/PHP]And it now looks ok.
- May 2008
September 29, 2008 at 10:01 am #273032And remove the image too
May 30, 2009 at 3:52 pm #306247Hi Bruce,
Would you mind sharing how you achieved your current layout
or [Left menu, main and right] with this iolite template, it’s something I would be interested in trying out but haven’t had any luck with so far?
Thanks,
Sincerely,E.
This topic contains 14 replies, has 4 voices, and was last updated by hshc 15 years, 7 months ago.
