Viewing 15 posts - 1 through 15 (of 18 total)
  • ballbank Friend
    #159274
    When view in iphone, the page only fill half of a screen fill (vertical), also can not change back to iphone version after view desktop version.
    My website is http://www.konthaiinus.com
    Thank you
    splico123 Friend
    #373674
    what version of JAT3 you running?
    i have same problem on the switching back to iphone too it seems.
    ballbank Friend
    #373675
    Forget to mention, I am on Joomla 1.6
    I think JA T3v2 I am new to the Joomlart community trying to catch up :-[
    Khanh Le Moderator
    #374179
    <blockquote>When view in iphone, the page only fill half of a screen fill (vertical)</blockquote>
    What have you made change on your site? It looks good on our demo.
    <blockquote>also can not change back to iphone version after view desktop version.</blockquote>
    We will update this feature.
    dminner Friend
    #374449
    I have the exact same problem with iPhone & JA Portfolio for Joomla 1.6.
    The problem exists when a mega menu dropdown has more than one column. It only shows the leftmost column on the iphone.
    Also, the exact same issue exists where once you switch to desktop version, you can’t switch back to iphone version. Please fix this on JA Portfolio as well!
    Thanks!
    ballbank Friend
    #374561
    I didn’t change anything on the template. I did clean install.
    Since I can’t change back from desktop version, I took a screen shot from your demo site (joomlart).
    1. photo
    rustyt Friend
    #374589
    I alos have the exact same issue.
    splico123 Friend
    #374597
    +1 on that issue
    xyzb Friend
    #374623
    Not sure if this is related.
    You have the following js error –
    Message: Object expected
    Line: 16
    Char: 31
    Code: 0
    URI: http://www.konthaiinus.com/t3-assets/js88862.js
    Did you change your menu/nav settings in the template manager? I noticed your not using the default mega menu.
    ballbank Friend
    #374635
    Oh I was working on it. I changed from mega menu to drop line and took out the cpanel.
    The problem is also apply to the joomlart teline 4 demo site itself.
    xyzb Friend
    #374640
    I just checked Joomlart’s online demo and there are no js errors in either IE or Firefox. I have the Firefox user agent switcher add-on loaded and just tested the site. It switches back and forth fine between desktop and I-phone unless I’m not understanding your issue.
    ballbank Friend
    #374657
    Please check on my attach image on page 1. The image was snapshot from my iphone. The same thing happened on my gf iphone also. The problem is all the content stack to the left of the screen. It doesn’t fill the whole screen like some of the template does, for example JA Rave display perfectly fine.
    xyzb Friend
    #374753
    Change your template settings back to the default with the mega menu on –
    Menu Type- magazine
    Menu System- mega
    Desktop Layout – default
    Handheld Layout – handheld
    Iphone Layout – iphone
    Android Layout – handheld
    If you are troubleshooting – you need to start from the default setting without things changed, then change one thing at a time and check it.
    I’m assuming that you have the latest download – quick start package.
    rustyt Friend
    #375136
    Just as a note. Per my previous post I was having the exact same issue with a fresh install of the J1.6 template and I hadn’t made a single change to settings etc having installed using the quickstart file. I didn’t resolve it.
    I’ve now reverted back to J1.5 version of template for other reason and the template now looks fine on tmy iphone so this might be J1.6 version specific.
    splico123 Friend
    #375252
    any answer on this issue pls? has anyone fixed or found out the problem with iphone layout?
This topic contains 18 replies, has 6 voices, and was last updated by  Khanh Le 13 years, 11 months ago.
