  • max_santiago Friend
    #203055
    Hallo joomlart friends and ja world lovers 🙂
    But… Is it possible setting Carousel module?!
    I say, is it possible without external module… but with JA module to create an horizontal images slider!? I remember old and epic JA Rasite and a good carousel module that used article images to create a dynamic thumbnails effect…
    Should I have to use ‘Ja Slideshow’ (with setting ‘use image folder’)?!
    But I use a default JA Slideshow and I haven’t understood how to configure – if it is correct procedure – a ‘cloned module’…
    I see on web many jquery plugins, but I ask to myself why don’t find a JA module…
    Thanks and hallo to all friends!
    Max
    Ninja Lead Moderator
    #556604
    JA Slideshow module does not use Carousel lib but you can use Source from image folder or Articles.
    JA Biz template is using Source: From Articles, you can see the full configuration from back-end of your site
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 10 years ago.
