  • Ch1vpH Friend
    #991927
    Hi – Just a quick one, I can’t see how to make a simple link inside JoomlArt Advanced Custom Module.
    How do I do this? As I need to create web links inside one, which is right in the middle of my homepage!
    I also need to add email mailto: links on another site of mine which uses a different JA ACM but is still a main part of my homepage which looks great but needs links to function better!!
    One is a Features Intro : style-absolute on JA Charity & the other is Features Intro : style-2 on JA Healthcare
    Thanks,
    Chris.
    Ninja Lead Moderator
    #992187
    If you want to run Features Intro : style-2 as JA Healthcare template on JA Charity template, you can follow the steps below
    • Download JA Healthcare template
    • Copy both files
      templates/ja_healthcare/acm/features-intro/tmpl/style-2.php
      templates/ja_healthcare/acm/features-intro/tmpl/style-2.xml
    • Paste them to templates/ja_charity/acm/features-intro/tmpl/ folder
    • Create the module and Features Intro : style-2 type under JA ACM module of JA Charity template
    For the Links you have to do custom work in ACM style files to add another option for links .
    Hope it helps
This topic contains 1 reply, has 2 voices, and was last updated by  Ninja Lead 8 years, 1 month ago.
