  • jeffersno1 Friend
    #162066
    Morning all,
    Wondered if you guys can help?
    I would like to use both menu types CSS and Split
    for example
    On the About us section i’d like to use the Split menu so i have links appear just under the bar
    On the Menu-select section id like to use CSS (the drop down effect)
    Has anyone tried this before ? is it possible?
    Many thanks
    Jeffers
    Arvind Chauhan Moderator
    #384212
    Hi jeffers,
    I am afraid its not possible to use two menu types at the same time. The template / framework does not support such feature.
    It may be possible to get it somehow working but that would take too much of code customization and rewriting the whole navigation structure and css styling, but you will need to hire some really good coder to get it done.
    Arvind
This topic contains 2 replies, has 2 voices, and was last updated by  Arvind Chauhan 13 years, 7 months ago.
