  • aardcom Friend
    #166788
    Is there a way to not show the site header and main navigation for an article in this template. I have a few pages that I want to show only custom modules and hide the others. There are no overides for this template and I’m not sure how I can accomplish this manually.
    #403889
    hi aardcom,
    You want to hide the header and top nav section for a determining article,right ?
    example you want to hide the main navigation in a article page you can try as below
    Open the file of templatesja_drimiaindex.php, Look for this
    <div id=”ja-mainnav”>
    <?php
    //Gen menu for CSS, MOO
    //Gen first level menu for Split, Dropline
    $jamenu->genMenu (0);
    </div>
    change it to
    <?php if(JRequest::getCmd(‘option’)==’com_content’ && JRequest::getCmd(‘view’)==’article’ && JRequest::Int(‘id’)==your article id goes here) { ?>
    <?php
    </div>
    <?php } ?>
    The snap code I added here help to detect if it is on a article page with a determine id
    Notice replace ‘your article id goes here’ with actual article ID.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 13 years, 4 months ago.
