  • AHMED Friend
    #1088896
    I have set the background image in masthead module to be fixed like in Ja Company Template.
    background-attachment: fixed;
    and I’ve made changes in css file "mod_jamasthead/asset/css"
    background-size: contain Not cover to let the whole image width to be fully seen, and position to be (position: top center !important) to avoid the blank space appear on the top of background-image.
      background-size: contain;
      background-position: top center !important;
    My issue is, if i open the website from my mobile (minimize), the background-image is pushed away ! same happens if I clicked on my keyboard F12 button to show the firebug, I can not see the background-image.
    Could you please fix it?
    Thanks in advance.
    regards.
    Try to use background-size: cover;
    and see how it goes.
    AHMED Friend
    #1089191
    hello,
    I have tried all possible positions and even I search online to solve this issue from my side.
    I posted here because i failed to solve it and need you to have a look on this issue.
    Could you please solve it?
    Regards.
    I checked this page but still not see the suggestion above.
    I just helped you to put this custom CSS:
    .ja-masthead {
        background-size: cover !important;
    into the file: /templates/ja_lawfirm/css/custom.css
    and it seems to be fine now, kindly check.
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 6 years, 10 months ago.
