June 1, 2010 at 11:09 am #151504
Hi all,
We got an issue with the way modules display in menu items Articles> Section / Blog and all articles.
Al menu items Articles> Category / Blog have a normal display like the HomeFor example the issue occurs in the following urls:
http://www.isfitness.nl/Voeding/ (this url doesn’t display images in the modules in the Collmass, left and right)
http://www.isfitness.nl/Voeding/Afvallen/ (this url has the correct display)
http://www.isfitness.nl/Voeding/Afvallen/afval-fouten-top-10 (this url also doesn’t display images in the modules in the Collmass, left and right)Also the images are not being showed or either found when clicking on an image in an article. For example click on the image in the url http://www.isfitness.nl/Voeding/Afvallen/afval-fouten-top-10.
I don’t know how this happened and how we can solve this. But the image display in the popup after clicking an image occurred after this massage :
______________________________________________________________________
Dear Tim,I just try to remove the url that refer to http://www.isfitness.nl/plugins/system/plg_japopup/fancybox/js/jquery-1.3.2.min.js file
But the issue still appeared,I am afraid that the issue lie on another conflict, please try to disable your other extensions to find out what caused this issue.
Sincerely,
XXX XXX XXX
JoomlArt.com Customer Service.
http://www.joomlart.com
_____________________________________________________________________We really want to solve this problem as quick as possible. We wanted to go live today. We have tried everything but can not find the cause of the problem
If anyone can help we would be very happy.
Is it nessisary to update to a newer version of joomla (1.5.18)??Kind regards,
=Fitness team
gray Friendgray
- October 2009
- 292 times in 230 posts
June 2, 2010 at 6:00 am #345614The links your posted are not working right now.
But as far as I can see from the reply, there is a JavaScript conflict. Have you installed any module/plugin which is not Joomla standard and is not inlcuded in Teline III package.June 2, 2010 at 7:13 am #345622Thank you for your reply.
I hope that it can be of any help. I have searched for the cause of the issue and found that it is caused with the use of “SEO instellingen”
When I set the “Zoekmachinevriendelijke urls” to “Ja” the issue appears (see http://www.isfitness.nl/index.php/training).
When I set this to “Nee” it looks fine again (see attachment)Strange detail is that when you go to the url above (Menu item Kracht) you see RSS in the position JA Mega item and you don’t see the positions Collmass, Tabs, Left and Right anymore. And we set it all as in the other menu items like “Voeding”
I hope this is useful and that you have a solution for it.
I can provide you with de login codes buit I will need your e-mail adres.Kind regards,
Tim
Sherlock FriendSherlock
- 2478 times in 2162 posts
June 3, 2010 at 10:18 am #345862Hi Tim,
Just install again the SEF plugin and your issue has been solved
June 3, 2010 at 10:30 am #345865Thank you!
I didn’t know that until today. Your colleague Hoang fixed it for us.
Still the thumbnail doesn’t show after click. The popup works but there is no image.
It works fine when we disable SEF.What can we do?
Regards Tim
This topic contains 5 replies, has 3 voices, and was last updated by isfitness 14 years, 7 months ago.
