  • brookh Friend
    #188065
    When viewing this responsive template on an IPhone I am required to double slide to move the content on the page. This causes the frame to have a slight movement causing the need for two consecutive slides vertically to scroll threw the content. I have narrowed the issue down to the off-canvas.less. It seems the Overflow-y areas starting around line 32 may be the cause. I added overflow-y: visible with some mixed results. Any idea the cause? I could really use some insights.
    MoonSailor Friend
    #495211
    Hi brookh,
    Could you send PM for me with url and admin login info of your site for closer checking?
    brookh Friend
    #495369
    Sent you the info.
    MoonSailor Friend
    #495426
    Hi brookh,
    I tried to check with iPhone but I didn’t see any error. You site’s running normally.
    Kindly check again.
    brookh Friend
    #495509
    Try sliding upwards after the site loads. You will notice a slight play in the top image. This causes the user to slide up twice to get the content to move. I cannot find what is causing this error.
    MoonSailor Friend
    #495599
    HI,
    Pls send PM to me with ftp account of your site. I need the same for a closer check.
    Ninja Lead Moderator
    #495600
    Right now its difficult to guess the issue and give solution to you. Provide your site url and include a illustrated screenshot highlighting the issue.I might be able to help you out then.
    brookh Friend
    #495663
    I will private message you the details immediately.
    brookh Friend
    #495689
    Here is a screen shot with markups.
    1. phonescreenshotMarkedup
    MoonSailor Friend
    #495758
    Hi brookh,
    It’s bug of this template. I’ll contact with template team and fix it soon. You can check the status here : http://pm.joomlart.com/browse/JATCFUBIX-129
    brookh Friend
    #495835
    Thank you, I am shutting down the access account. E-mail me if you need it to be reactivated.
This topic contains 11 replies, has 3 voices, and was last updated by  brookh 11 years, 6 months ago.
