July 24, 2007 at 8:48 pm #121614
Nerine works fine with Firefox
I faced these two issues while using ja nerine with internet explorer.1. With ie 6 the right column is going all the way down.
2. With ie 7 the bottom modules float in the middle of the page.
This the URL
http://www.iitmaaglobal.comPls Help!!!
-Vivekstuart29 Friendstuart29
- August 2006
July 24, 2007 at 11:32 pm #225021<em>@datanet 21952 wrote:</em><blockquote>Hi
This the URL
-Vivek</blockquote>your modules are meant to be in the middle y don`t you use the right module to display your latest events module, even the site up a little bit more uniformedalso your top image is to wide site sponsers
i would say you need to fix your images there to big plus use the right module more you have a lot of space
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
July 25, 2007 at 3:20 am #225032You should reduce the width of Slideshow module to 668.
July 25, 2007 at 1:40 pm #225079i reduced the width of the slideshow to 668. But No Luck.
July 25, 2007 at 1:42 pm #225081The issue is still there even if i remove the spotlight module from the bottom. Pls check http://www.iitmaaglobal.com
i removed all the modules in the spotlight. Still i face the issue.Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
July 25, 2007 at 7:47 pm #225104Unpublish the slideshow, the calendar and the sponsors at top, do you still have that problem then?
If not, publish, the calendar module. Ok or not?
Publish site sponsors module, Ok or not?
Publish the slideshow module. Ok or not?Do that in the steps there and see where it breaks out
Give us a reply about itJuly 25, 2007 at 9:18 pm #225114Thanks a million.
here is it.
Unpublish the slideshow, the calendar and the sponsors at top, do you still have that problem then? No problemIf not, publish, the calendar module. Ok or not? no problem
Publish site sponsors module, Ok or not? no problem
Publish the slideshow module. Ok or not? Yesthe problem was coz of the slideshow module. But how to enable it without this issue?
- May 2007
July 25, 2007 at 10:17 pm #225129Try to change the width of the slideshow to 500px first and see if that helps?If it does you can take it step by step up until 640px if it doesnt break out and see how it looks then?
August 1, 2007 at 8:26 pm #226042it doesn’t work. i started with 300px.. no luck…Any other idea?
- May 2007
August 1, 2007 at 9:14 pm #226049Can you pm me admin access?
November 16, 2007 at 11:03 pm #232961I’m having the same problem with the footer (grey bar with module positions 5,6,7,8,9) in IE7. Works fine in FireFox. Is there a fix for this problem? Thanks.
BKSaunders
December 6, 2007 at 4:10 am #234012Is there any anwer to this issue? I’ve already spend hours trying to solve it but :confused:
January 4, 2008 at 11:33 am #235708Was this ever resolved?
February 5, 2008 at 3:39 pm #238264Has this issue been resolved? I am having the same problem. In IE7, the footer floats to the middle in some cases. The slideshow module is disabled; so this can be ruled out. I have been trying for hours to come up with a solution but have been unsuccessful. Please help!
Thanks.
This topic contains 27 replies, has 12 voices, and was last updated by Saguaros 14 years, 1 month ago.
