amir00251 Friend
amir00251
- January 2011
- 11 times in 1 posts
November 14, 2011 at 5:06 pm #170690when I enable project fork themes (any of them) I get top panel buton separating and moving to the sides (image attached above).
I have looked at the css but I could not find what is the problem.
I can sort this out by defining absolute position for left, middle, and right images of the buttom but I dont think it is a good idea. Any suggestions welcome.
Thank you.
khoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
November 14, 2011 at 5:12 pm #424619Hi,
Could you give me a link to your page as you said?amir00251 Friendamir00251
- January 2011
November 14, 2011 at 5:25 pm #424621Hello and thanks for quick reply. I sent the link to you by message. Also if you could make a suggestion to show top panel in IE9 i will be grateful. It is several months IE9 has been released and top panel module has not yet been updated by joomlart. Thank you.
khoand Friendkhoand
- February 2011
November 14, 2011 at 5:29 pm #424622You go to Template manager,choose JA Portfolio template, then change CSS Optomize fieds to NO, so I can check how and where to customize for you.
- January 2011
November 14, 2011 at 5:30 pm #424623Thanks I just turned off css optimisation.
khoand Friendkhoand
- February 2011
November 14, 2011 at 5:38 pm #424625You login bakend > Extensions > Template Manager > JA_Portfolio – Default > GLOBAL > Css & Javascript Compress . Edit Optimize CSS to No .
- January 2011
November 14, 2011 at 5:40 pm #424626As I said, I have done this. Sorry I remembered I have also installed jfinalizer which does compress css. I have not turn that off too so there should not be any problem.
khoand Friendkhoand
- February 2011
November 14, 2011 at 5:47 pm #424628You find this code from /templates/ja_portfolio/css/mod_jatoppanel.css
.ja-toppanel-button-wraper .left .ja-toppanel-button-r {
background: url("../images/button-right.png") no-repeat right;
height: 23px;
width: 35px;
float: left; < add this line
}amir00251 Friendamir00251
- January 2011
November 14, 2011 at 5:52 pm #424630Ok, this solve part of problem. Now the right image of the buttom came to the left and joined the middle part. Now I have whole buttom in the left of the screen. How should I centre align. Thank you.
khoand Friendkhoand
- February 2011
November 14, 2011 at 6:00 pm #424631You replace this code from /modules/mod_jatoppanel/assets/style.css
div.ja-toppanel-button-wraper .left {
float: left;
margin: 0;
with
left: 500px!important;
margin: 0;
}1 user says Thank You to khoand for this useful post
- January 2011
November 14, 2011 at 6:21 pm #424635Hello, Thank you issue has been resolved in firefox or chrome but in IE8 or IE7, I have the top panel buttom a bit to the right of screen.
When I look closely it seems that IE handels the template totally different, even top menu and amount of space I have left after menu items is different in IE.
- January 2011
November 14, 2011 at 6:53 pm #424637<em>@khoand 282681 wrote:</em><blockquote>You replace this code from /modules/mod_jatoppanel/assets/style.css
float: left;
margin: 0;
}with
margin: 0;
</blockquote>Hi I think I have found the solution
code from /modules/mod_jatoppanel/assets/style.cssreplace
float: left;
margin: 0;
}with
float: left !important;
margin: 0;
}and replace
div.ja-toppanel-button-wraper .right {
right: 10px;
height: 0;
overflow: hidden;with
float: right !important;
right: 10px;
height: 0;
overflow: hidden;1 user says Thank You to amir00251 for this useful post
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 2 voices, and was last updated by amir00251 13 years, 1 month ago.
issue with ja top panel buttom when enabling projectfork themes
