jethro Friend
jethro
- 5 times in 1 posts
June 15, 2015 at 3:08 pm #207424Hi there,
I am having some issues with my module class suffixes. See the problem here: http://www.smart-drones.com
And the screenshot below:
As you can see I want the custom HTML module class to have a yellow border on top and a background texture.
I have added to the module class suffix in the Joomla backend:
_home
And I have added the following code to custom.css
.t3-wrapper div._home {
background-image: url("http://www.smart-drones.com/images/home/home.png");
background-size:cover;
background-color: #FFFFFF
background-repeat: no-repeat;
background-position:center top;
background-size:;
width: 100%;
height: 100%;
background-attachment:none;
}As you can see it does not work and breaks up the image…
What is the correct way to add a custom module class suffix?
Many thanks in advance,
Jethro.
June 16, 2015 at 1:45 am #574141Hi
As i can see the yellow border is coming from the module suffix -black top
here >>> http://prntscr.com/7hghmr
Also _home background is showing fine in bg image as you added in css
here >>> http://prntscr.com/7hgi8l
Please check its working fine , if any issue added screenshot and illustrate complete details in it so i can check it for you.Pankaj Sharma ModeratorPankaj Sharma
June 16, 2015 at 1:45 am #640480Hi
June 16, 2015 at 1:45 am #739155Hi
Please check its working fine , if any issue added screenshot and illustrate complete details in it so i can check it for you.AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by Pankaj Sharma 9 years, 4 months ago.
Issue with module class suffix
