  • Upendra Friend
    #926701
    Hello again,
    I also discovered another issue with tabs when you have a module either on sidebar 1 or sidebar 2. If you use the tabs as shown on Typography then there is a big issue with the collapsing of the tabs.
    For example you have little content in Tab 1 and it’s your currently active tab, you go to Tab 2 where there is very long content. If you come back to tab 1 again after Tab 2 then the Tab change but the WHITE SPACE under Tab 2 won’t collapse. Please see the screenshot 1, 2 and 3.
    1. tab1
    2. tab2
    3. white-space
    Pankaj Sharma Moderator
    #926915
    Hi Thanks for report , i am replicating this issue on fresh package , I will back to you with results . stay tuned ..
    UPDATED :
    Hi its a bug in the template i reported it to development team for further investigation and fix .
    It will be fixed in the next version of template . You can track it here
    Thanks for your report and patience in this matter .
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 8 months ago.
