robnob Friend
robnob
- October 2011
- 2 times in 1 posts
March 10, 2012 at 4:21 pm #174832I also posted into K2 and their support is not responding… see here http://getk2.org/community/New-to-K2-Ask-here-first%21/9433-NEW—Social-Sharing-no-longer-appear#9433
In my new site i can post articles without a problem but i have noticed stuff starting to mess up and wondering if someone can provide assistance.
1. The K2 social share buttons no longer appear…
2. Sometimes the K2 articles do not appear on the frontpages JAcontentslider (i have to refresh a few times)
3. I no longer can “comment link” on other people comments
4. When “Add new item” the K2 display takes up the full page and not a popup?Thanks for any suggestions/help
The only thing different i’ve done is add Googla Adsense and Phoce Google Adsense module. I have displayed all of the modules in hopes that it would fix and still didnt.
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
March 10, 2012 at 4:29 pm #442890Hi,
May i ask if after you enabled Google Adsense you cleared the JAT3 cache and even better i would suggest to disable CSS and JS optimization and see if this solves the problem.
robnob Friendrobnob
- October 2011
March 10, 2012 at 7:46 pm #442912after clearing JAT3 Cache i received this
DB function failed with error number 1194
Table ‘jos_session’ is marked as crashed and should be repaired SQL=SELECT guest, usertype, client_id FROM jos_session WHERE client_id = 0also i cannot login to the admin page…
jtablesession::store failed
DB function failed with error number 1062
Duplicate entry ‘1-‘ for key 2 SQL=INSERT INTO `jos_session` ( `session_id`,`time`,`username`,`gid`,`guest`,`client_id` ) VALUES ( ‘e1770143c24672bc838ff5e829ee3a07′,’1331408456′,”,’0′,’1′,’1’ )
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 16 bytes) in /home/staysu5/public_html/big3fantasy.com/libraries/joomla/error/exception.php on line 117Any ideas?
- February 2014
March 11, 2012 at 6:55 pm #443019Hi,
Well that explains a lot, your db is crashed and needs to be repaired, try by using the build in function on phpmyadmin to repair or ask your host to help you.
Also an other message that i can identify is that your php.ini settings limit the amount of memory that Joomla can use or a 3rdparty plugin consumes a lot of memory (which is more possible).
Both issues do not relate to JAT3 cache or clearing cache issue.
Regards.
- February 2014
This topic contains 6 replies, has 2 voices, and was last updated by robnob 12 years, 9 months ago.
