  • simmo Friend
    #146821
    I want the JA-SLIDESHOW without anything in it – just as a module position where I can use the class module suffix as “_clear” and just use a header-picture of my choice.
    And I want the header picture to go all the way up to the meny and down to the content-slide.
    Then I would like to use the BODY as a normal frontpage with one column. The resized pictures her is actually a good idea for my use. As it is now there are a lot of problems with the two columns and some mixup with the pictures and the content headings…
    Check it on my test site: http://www.gofoto.nu
    Could anyone help me with this please.
    cheers
    simmo
    1. body
    2. header
    Anonymous Moderator
    #326619
    Hi simmo
    – for body: open template.css file, add following code to the end of file:
    .leading {
    float:left;
    – For slideshow, please open template.css file, at about line 1093, find following code section:
    /* Top spotlight */
    #ja-topslwrap {
    background: url(../images/botsl-bg.gif);
    padding: 20px 0 0;
    z-index: 8;
    here you change the padding to your idea.
This topic contains 2 replies, has 2 voices, and was last updated by Anonymous 14 years, 11 months ago.
