  • optionsizzle Friend
    #138948
    I am having issues with the titles and text being different sizes in each post in blog layout.
    here is my site http://www.optionsizzle.com
    Also when you click on an article the bottom menu comes out of place and both of these issues only happen in IE.
    Can use help ASAP
    hexagon Friend
    #299479
    I have the same issue, I have logged a ticket with Joomlart tech support, so I’ll try to pass on the fix, if any!
    optionsizzle Friend
    #299482
    Hexagon,
    Thanks for the reply and if you can keep me updated i would like that. I also put in a request and never heard back from them. I would like to figure it out my issue with the font title being different sizes and footer out of place.
    nguyenhuu quang Friend
    #299500
    hi, pls contact via my PMB . may i help you
    hexagon Friend
    #299672
    I have found out what was causing my issue. The flowlist module that i was using was designed to be placed above the ja-contentwrap. As i was trying to get it to work within the ja-contentwrap it was causing the issue in IE7. I have not yet had a reply from Joomlart as to why it won’t work, but maybe you have a module published in a similar manner.
    If i hear anymore i will let you know.
    James
This topic contains 5 replies, has 3 voices, and was last updated by  hexagon 15 years, 9 months ago.
