  • pluriel72 Friend
    #163404
    It seems there is a Problem with Internet Explorer. Have a look on my Site http://www.pattscheid.de, there is no left and right column. Ì´m also missing some text below the second pic. Third article is not availible….
    Phill Moderator
    #389084
    The problem is that you have pasted content to either an article or a module from a word document. This is really bad ad the layout of word documents contains html which IE browsers try to parse. I can see that you have done that in at least 2 different items.
    The 2 code snippets from your view source should help you locate the articles/modules with the problems.
    <a class="moduleItemTitle" href="/index.php/pa-ro-li/dg-pattscheid/item/518-maibaumaufstellen-2011">Maibaumaufstellen am 01.05.2011</a>
    <div class="moduleItemInfo clearfix">
    <span class="moduleItemDateCreated clearfix">
    <span class="date">28</span>
    <span class="month-year">
    <span class="month">Apr</span>
    <span>2011</span>
    </span>
    </span>
    <a class="moduleItemComments" href="/index.php/pa-ro-li/dg-pattscheid/item/518-maibaumaufstellen-2011#itemCommentsAnchor">
    0 Comment </a>
    </div>
    <!-- Plugins: AfterDisplayTitle -->
    <!-- K2 Plugins: K2AfterDisplayTitle -->
    <!-- Plugins: BeforeDisplayContent -->
    <!-- K2 Plugins: K2BeforeDisplayContent -->
    <div class="moduleItemIntrotext">
    <p><!--><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <w:PunctuationKerning /> <w:ValidateAgainstSchemas /> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables /> <w:SnapToGridInCell /> <w:WrapTextWithPunct /> <w:UseAsianBreakRules /> <w:DontGrowAutofit /> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><!--><!--><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><!--><!-->
    <style>
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Normale Tabelle";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    </style>
    </p>
    <style>
    font-size:10.0pt;
    </style>
    <p class="MsoNormal"><img class="caption" src="/images/stories/allgemein/maibaumsetzen.jpg" border="0" alt="Maibaufstellen" title="Fleissige Jugend" /></p>
    p class="MsoNormal">Am 1. Mai laden die Dorfgemeinschaften Pattscheid und Romberg-Linde ihre Mitglieder zum traditionellen Maibaumaufstellen an der Hüburg ein. Ab 11 Uhr werden wir gemeinsam mit der Maikönigin den Baum schmücken und ihn anschließend aufstellen. Für Speis und Trank ist gesorgt.</p> </div>
    and the second
    <a class="moduleItemTitle" href="/index.php/pa-ro-li/dg-pattscheid/item/517-tanz-in-den-mai">Tanz in den Mai am 30.04.2011</a>
    <span class="date">22</span>
    <span>2011</span>
    </span>
    </span>
    <a class="moduleItemComments" href="/index.php/pa-ro-li/dg-pattscheid/item/517-tanz-in-den-mai#itemCommentsAnchor">
    0 Comment </a>
    </div>
    <p><img class="caption" src="/images/stories/allgemein/tanz_in den_mai_458.jpg" border="0" alt="Tanz in den Mai" title="Tanz in den Mai" /></p>
    p><!--><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <w:PunctuationKerning /> <w:ValidateAgainstSchemas /> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables /> <w:SnapToGridInCell /> <w:WrapTextWithPunct /> <w:UseAsianBreakRules /> <w:DontGrowAutofit /> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><!--><!--><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><!--><!--> <mce:style><! /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} --> <!-- --></p>
    p class="MsoNormal">Seit vielen Jahren begrüßt<span> </span>die Dorfgemeinschaft Pattscheid in Haus Klippenberg<span> </span>den Mai. Auch in diesem Jahr wird am 30. April wieder ab 20 Uhr getanzt, gesungen und gefeiert.<span> </span>Als Highlight gilt die Wahl der Maikönigin, die kurz vor Mitternacht gekürt und mit dem amtierenden Dorfkönig das Tanzbein schwingen darf. Zusätzlich zur guten Musik der Band „Let´s D<a name="_GoBack"></a>ance" sorgt eine attraktive Tombola für tolle Stimmung.</p> </div>
    pluriel72 Friend
    #389094
    Thx a lot. Problem is solved.
This topic contains 3 replies, has 2 voices, and was last updated by  pluriel72 13 years, 8 months ago.
