  • Mestr Friend
    #160912
    Hello. I’ve installed JA_Events “QUICKSTART” with sample data.
    Okay, no problem.
    Then I bought the module and the JW Player’ve installed the Ja_events 1.6.
    After the module data changes, I can not save data.
    Module JW Player admins say that the fault was “QUICKSTART” database.
    Here’s our conversation:
    Mestr: <blockquote>
    “Openings JWPlayer module.
    After the parameters (Palylist, Layout, Global,…) changes by clicking the “Save”.
    Then (about five seconds) on my computer the “CPU Usage History” of 100%.
    But the module parameter data is stored.
    I am using Joomla 1.6 and JW Player 2.8.0 Advanced Module 13
    Please help.”
    </blockquote>
    JoomlaRulez Admin:<blockquote>Hi,
    this come from an SQL issue of Joomla 1.6 RC1, you have to upgrade to Joomla 1.6 file AND database, see here :
    http://www.joomlarulez.com/forum/27-jw-player-module-advanced/1561-support-for-joomla-16.html#1654
    http://www.joomlarulez.com/forum/27-jw-player-module-advanced/1676-joomla-16-install-error.html#1679</blockquote>
    If it is true, then please restore the “QUICKSTART” database.
    #379435
    Dear Mestr,
    I am not sure when you said the problem was caused by joomla 1.6 RC1,I think all of our quickstart packages was built with the joomla 1.6 stable version
    Kindly check it again !
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 13 years, 10 months ago.
