  • eminovpress Friend
    #161220
    Why there is no Section 1.6. Or have I just do not know? :confused:
    khoand Friend
    #380542
    you download JA Anion for Jomla 1.6 at http://www.joomlart.com/forums/downloads.php?do=cat&id=20313
    eminovpress Friend
    #380558
    I download. And installed quickstart. But in admin page not section field.
    Phill Moderator
    #380561
    That is the way J1.6 now workes. Gone are the old Category/Section setup in favour of nested categories. This gives a lot more flexibility.
    Hopefully the following will explain fully how it all works and why – http://community.joomla.org/blogs/community/1237-categories.html
    eminovpress Friend
    #380582
    I post article subcategory. Because the post can be added to only one category. And when I clikc the “kosmos” category of post to be seen. The post can only be seen on the subcategory when I’ve put in the article.
    Phill Moderator
    #380585
    I am not quite sure what you are asking here. Can you be a little more detailed?
    eminovpress Friend
    #380591
    I added article “Planetler” category. But this category subcategories “kosmos”.
    When I click “kosmos” category my article not visible. On the category nothing happens.
    But subcategory visible…
    Phill Moderator
    #380594
    Maybe the language barrier is too mich for me here. Hopefully someone else will chip in.
    In the meantime I suggest you raise a support ticket and include a link to your site and an admin logon so the team can investigate for you.
    eminovpress Friend
    #380720
    in this photo category and subcategory
    when new not is added it’s possible to choose category, then I choose suitable subcategory for the note and published. Then, published note can be seen in subca aftetegoryr the update page. It’s impossible to see subcategory’s notes in category. Fot it I must must add main category, in this case there is not to be able to add new subcategory.
    but in J1.5 I did it with the “section”
This topic contains 9 replies, has 3 voices, and was last updated by  eminovpress 13 years, 9 months ago.
