October 30, 2016 at 8:17 pm #981807
Hi There,
There seems to be a problem with the JA ACM Module. Im trying to make some configuration settings in places such as "Module Tag", "Bootstrap Size" and Class. But its not taking those changes at all. This seems to be a problem n needs to be rectified.
October 31, 2016 at 1:16 am #981885Hi
Kindly open the module > options > Module style > xhtml , then try to change the size .
By the way, the size of the module depends on the module position size if you will change the size from bootstrap options and its different from the module position container size . It may create an issue in style of the module .October 31, 2016 at 9:05 am #982004This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
October 31, 2016 at 1:42 pm #982079Hi
You can see the option in your screenshot .
Here : http://prntscr.com/d18tz3
make it xhtml save and check .November 1, 2016 at 9:14 am #982325Hi There,
I’ve tried that its adding a span6 (for bootstrap 6) but the styling is not getting applied. Is bootstrap grid included in the css? or do i have to include it separately to make it work?
November 1, 2016 at 9:34 am #982327Hi template is based on bootstrap 3 and you have not need to add it. Its already applied on module positions.
November 1, 2016 at 9:43 am #982329This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
November 2, 2016 at 1:41 am #982566Hi
The span6 is working on your site : http://prntscr.com/d1xzyl
But as I said if you will override it will break the design , new-home is the custom position .
As u can see in gallery ACM module its in two parts one in left and one is sidebar-1 . -
This topic contains 7 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 10 months ago.
