March 12, 2013 at 9:00 pm #185779
I’m using the latest JA Mitius template, I’ve already installed it, I test it with a few articles, but only the images and the healine is showing up on the front page, when one clicks on the link, it opens a blank page…. even though I can see the whole article in the back end. Please someone help.
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
March 13, 2013 at 9:52 am #486316Hi Jocobinnoir,
Thank you for your feedback. But did you try to install our JA Mitius quickstart packages which can make your site looks like our demo. If you just install our JA Mitius template only, I have to create/import more articles/module.
In addition, your issue is quite stange to me, so can you make a snapshot & send me a PM with your admin, I’ll help to check out which cause your current situation on your site.Regards,
Leo1 user says Thank You to phong nam for this useful post
kuerten Friendkuerten
- March 2012
- 4 times in 5 posts
August 12, 2013 at 11:52 am #501974Hello, I have the same problem. I try to install the quickstart template JA Mitius .. and after install .. just after delete the installation file … I have blank page on front page … same thing with administrator page ::: could you help me please ?
- May 2015
August 12, 2013 at 2:45 pm #501983Hi crea2011,
I will help to check out your issue when you can send me PM with your website’s credentials ?
August 13, 2013 at 1:46 pm #502091Hello again,
In fact … I found the problem … It was just update php .. thanks<em>@Leo Burnetts 384528 wrote:</em><blockquote>Hi crea2011,
I will help to check out your issue when you can send me PM with your website’s credentials ?</blockquote>
August 28, 2013 at 9:57 am #503766I have the same problem….
- May 2015
August 29, 2013 at 9:24 am #503911Hi jellylife,
I do not see active club membership in your profile and so it would not be possible to help you out for this commercial extension. Support and download access are available only to active paid members, at the same time we provide limited support (bug fixes) for our free products, however, the one you are using is not a free product. Please signup and be our club members and i will try to help you then.
This topic contains 8 replies, has 5 voices, and was last updated by phong nam 11 years, 3 months ago.
