February 25, 2008 at 11:20 pm #126016
I try to install this template. It’s perfect for my web page about underwater photography. I have RSgallery installed correctly, and I try to have the JA Header Module from JA_Villadi under the logo. With FireFox everything seems ok but with IE7 when the JA_Header start stop the carge of the page with a system mesage: “IE can’t open this site” and in the backgroun of thirs mesage the module (JA_Header is working ok!!!)
I try to explain wath I do: (Excuse my poor English)
I just paste before the logo code this:
<!– BEGIN: HEADER –>
<div id=”ja-headerwrap”>
<div id=”ja-header”><?php if( mosCountModules(‘header’) ) {?>
<div id=”ja-sh” class=”clearfix”>
<?php mosLoadModules(‘header’, -1); ?>
</div>
<?php } ?><h1 class=”logo”><a href=”index.php” title=”<?php echo $mosConfig_sitename?>”><?php echo $mosConfig_sitename?></a></h1>
I Write the id ja-sh in the CSS page, and have the module active in header of course…
My joomla version is: Joomla! 1.0.12 Stable [ Sunfire ]
My web page is out of order till i finish the adaptions… http://www.mardigital.netI look for a solution all the night…. I’m not not code writer, only try to learn and enjoy…
Hung Dinh FriendHung Dinh
- 3310 times in 3 posts
February 26, 2008 at 5:49 am #240176You site is offline at the moment, please PM me your fpt information and I can have a look.
1 user says Thank You to Hung Dinh for this useful post
Sherlock FriendSherlock
- 2478 times in 2162 posts
February 27, 2008 at 7:21 am #240342Hi MarDigital.
I’ve viewed your site, you can fix that error by login admin site,choose to edit JA Header Module. You can see one paramater is Header type (have two values: Flash SlideShow , and Javascript Fade SlideShow). Plz choose Javascript Fade Slideshow, your site will run okie on IE7.
Hope can help you.Sherlock FriendSherlock
February 27, 2008 at 9:39 am #240384Hi MarDigital.
If you use Flash SlideShow, your site will have error is conflict javascript file between JA Header Module and Avian II. You should remove JA Header Module, if you still want to use JA Header Module , plz config module as I said before , and you must change some css code.
Good luck1 user says Thank You to Sherlock for this useful post
February 27, 2008 at 1:07 pm #240400<em>@nguoiabcd 42073 wrote:</em><blockquote>Hi MarDigital.
Good luck</blockquote>Thanks a lot!
Now its working perfectly. I only have to change some css parameters of the page.
Chers,
February 27, 2008 at 1:18 pm #240401<em>@nguoiabcd 42027 wrote:</em><blockquote>Hi MarDigital.
Hope can help you.</blockquote>I do it and the site charge Ok but the slideshow of JA Header dont run… :confused:
This topic contains 6 replies, has 3 voices, and was last updated by MarDigital 16 years, 10 months ago.
