May 10, 2007 at 10:05 pm #120188
I installed JA Bellatrix to my Mambo 4.6.1 site. And I am having problems with the left alignment of the modules – they are too squished up to the left (see attachment).
Is this a padding or margin problem – if so which?
I don’t have the same problem with J A Pollux so I presume it is a css issue rather than a Mambo problem.
Hope you can help.
Terry
ShannonN FriendShannonN
- July 2006
- 172 times in 49 posts
May 11, 2007 at 6:23 am #219890Shortwave;15204I installed JA Bellatrix to my Mambo 4.6.1 site. And I am having problems with the left alignment of the modules – they are too squished up to the left (see attachment).
Hope you can help.
Terry
It could be a Mambo problem Pollux may not use reserved words or stuff that Bellatrix does, drop a copy of Joomla onto a sub domain etc and test
Mambo is getting old now, maybe time to step up to Joomla?Cheers ShannonN
May 11, 2007 at 10:47 pm #219923OK – worked it out. It can be solved easily using the CSS. The tags are ja-leftcol and ja-rightcol and they need a qualifier of margin-left: 5px;.
Easy when you know how!AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by shortwave 17 years, 6 months ago.
JA Bellatrix left column alignment problem
