  • mediabw Friend
    #1090752
    Hello Joomlart, we use ja builder in firefox for a lot of pages and since last update, we have a lot of problems on different pages.
    For example, changing html doesnt work. We have to duplicate another text block and paste the changed html to publish it. Changes in html cant be saved without this workaround.
    We try Internet Explorer, Firefox and Chrome. The only browser we can work is Firefox, in chrome we cant publish anything for example. But the problems are the same in Firefox.
    So what happend. We clean the cache and browser history, we updated builder and for try, joomla to latest version.
    Actually, we work @http://bw-media.gmbh/partykochpeitler
    We change 1 page and after publishing, the menu structure is displayed totally wrong.
    On other pages, we try to publish changed builder sites and the output isnt display like in builder. its not responsive or totally different.
    We need a fast bug fix.
    Its a problem, if more then 1 page is produced on 1 webspace? We have different databases, but its all the same Domain, for example: http://bw-media.gmbh/partykochpeitler/ http://bw-media.gmbh/tvwellesweiler/ http://bw-media.gmbh/consulting-schuler/
    Kind regards Christian
    • This topic was modified 6 years, 10 months ago by  mediabw.
    mediabw Friend
    #1090763
    Problems @ Partykochpeitler temporally solved. We change the menu in joomla backend (the menu-order), then it works for the moment. But the other problems still there.
    and @https://sbi-sanierung.de/_web2017/
    • This reply was modified 6 years, 10 months ago by  mediabw.
    Could you share the login info of site that you’re facing issue with? and tell me the details of the changes so I can replicate issue and check for you.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 6 years, 10 months ago.
