balgev Friend
balgev
- May 2011
October 18, 2011 at 11:01 am #169784Hello
please tell me how to change the time format in ja bulletin, from 17.10.11 ( DATE_FORMAT_LC4 ) to Hour and minute format, for example
14:20 (24 hour)i opened the file administrator/language/en-GB/en-GB.ini
where i saw
# Date format
DATE_FORMAT_LC=%A, %d %B %Y
DATE_FORMAT_LC1=%A, %d %B %Y
DATE_FORMAT_LC2=%A, %d %B %Y %H:%M
DATE_FORMAT_LC3=%d %B %Y
DATE_FORMAT_LC4=%d.%m.%y
DATE_FORMAT_JS1=y-m-d
%Y-%M-%D=%Y-%m-%d
%A, %B %E=%A, %B %eand searched internet for time format and found out that my wished format is %H.%i , but when i change the DATE_FORMAT_LC4=%d.%m.%y to DATE_FORMAT_LC4=%H.%i NOTHING IS CHANGED….
and besides this please go to my website page where ja bulltin is published
http://mardik.am/mardik1/index.php?option=com_k2&view=itemlist&layout=category&task=category&id=338&Itemid=419&lang=hyi disabled the images, and left only TITLE and DATE… and i want them to arrange next to each other
like this
19:20 – ITEM TITLE
i guess i must do it in css, but could not find…
Thanks!
pavit Moderatorpavit
October 18, 2011 at 11:23 am #419986Hi balgev
Try to change the LC4 format in the en-GB.mod_jabulletin.ini in language/en-GB
balgev Friendbalgev
- May 2011
October 18, 2011 at 12:49 pm #419998<em>@pavit 276716 wrote:</em><blockquote>Hi balgev
Try to change the LC4 format in the en-GB.mod_jabulletin.ini in language/en-GB</blockquote>
there is nothing about lc4 date format in en-GB.mod_jabulletin.ini in language/en-GB
JA BULLETIN DESC=<span style=”color: #008000;”><strong>JA Bulletin Module</strong></span><br /><p><img alt=”JA Bulletin Module” src=”http://static.joomlart.com/images/stories/extensions/joomla/ja_bulletin.png” /></p><ol></ol>This module behaves like default joomla most read and latest modules, but supports options to show date and thumbnail images. <ol></ol><p><span style=”color: #ff6600;”><strong>Features:</strong></span></p><ol><li>Show / hide Images in the list</li><li>Show or hide Date of the article.</li><li>Easy thumbnail generation, set your own dimensions.</li></ol><p><strong><span style=”color: #ff0000;”>Important Instructions :</span><br /></strong></p><ol></ol><ol><li>Keep your module updated with the latest version</li></ol><p><strong><span style=”color: #ff0000;”>Upgrade Methods :</span><br /></strong></p><ol></ol><ol><li>Standard joomla uninstall / reinstall method. OR</li><li>Module supports upgrade method. You can install new version directly over this version. Uninstallation is not required. Backup any customized file before upgrading, your settings would be saved though. OR</li><li>Use <strong><a href=”http://extensions.joomla.org/extensions/core-enhancements/installers/12077″ target=”_blank”>JA Extensions Manager</a></strong> Component for easy upgrades and rollbacks. <strong><a href=”http://www.youtube.com/user/JoomlArt#p/c/BC9B0C0BFE98657E/2/mNAuJRmifG8″ target=”_blank”>Watch Video.</a></strong></li></ol><ol></ol><p><span style=”color: #008000;”><strong>Links :</strong></span></p><ul><li><a target=”_blank” href=”http://www.joomlart.com/forums/forum/ja-compress-plugin/”>JA Bulletin Module Forum</a></li><li><a target=”_blank” href=”http://pm.joomlart.com/browse/JAECMODBULLETIN”>Report Bug</a></li><li><a target=”_blank” href=”http://update.joomlart.com/#products.list//JA%20Bulletin%20module%20for%20Joomla%201.5/”>Updates & Versions</a></li></ul><p>Copyright 2004 – 2010 <a href=”http://www.joomlart.com/” title=”Visit Joomlart.com!”>JoomlArt.com</a>.</p>
BOTH=Both
CATEGORY ID=Category ID
COUNT=Count
DISPLAY ARTICLES FROM = Display Articles From
DISPLAY ARTICLES FROM DESC = Display articles from desc
SELECT K2 CATEGORIES = Select K2 Categories
SELECT K2 DESC = Select k2 descFRONTPAGE ITEMS=Front Page Articles
MOD_JABULLETIN=<em>mod_jabulletin</em>
MODULE MODE=Module Mode
MOST READ CONTENT=Most Read Content
PARAMCATEGORYID=Selects Articles from a specific Category or set of Categories. Enter the Category ID from the Category Manager. To specify more than one Category, separate each ID with a comma.
PARAMFRONTPAGEITEMS=Show/Hide Articles designated for the Front Page. This only works when in Article-only mode.
PARAMSECTIONID=Selects Articles from a specific Section or set of Sections. Enter the Section ID taken from the Section Manager. To specify more than one Section, separate each ID with a comma.
SECTION ID=Section ID
THE NUMBER OF ITEMS TO DISPLAY (DEFAULT IS 5)=The number of Articles to display (the default is 5)
PARAMJABULTYPE=Show Latest articles or Most popular articles
PARAMSHOWIMAGE=If enabled, the first image in each article will be shown.
PARAMIMAGEWIDTH=Resize image width
PARAMIMAGEHEIGHT=Resize image height
PARAMSHOWDATE=Show/hide last update date
CATEGORIES SELECTION=Categories selection
SELECT CATEGORY ITEMS(S) FROM LIST YOU WOULD LIKE TO DISPLAY LIST OF ARTICLES=Select category item(s) from list you like to display list of artciles
CACHING=Caching
SELECT WHETHER TO CACHE THE CONTENT OF THIS MODULE=Select Whether To Cache data after made SQL query to fetch data from database.
USE GLOBAL=Use global
NO CACHING=No caching
CACHE TIME=Cache Time
THE TIME BEFORE THE MODULE IS RECACHED=The time before the module is recached
UNCATEGORIZED=UncategorizedUSING IMAGE SOURCE=Using Image Source
USING RESIZE=Using Resize
USING CROP=Using Crop
IMAGE SETTING=Image Setting
THUMBNAIL MODE=Thumbnail Mode
THUMBNAIL MODE DESC=If you like use image thumbnail which render from the image source, then you choose ”crop” or ”resize”
RESIZE WITH THE RATIO=Resize With The Ratio
RESIZE WITH THE RATIO DESC=If you choose ”yes”, then the module will render a thumbnail with the ratio about dimension of the image source
DISPLAY ARTICLES FROM DESC = Display article from joomla categories or k2 categories
PARAMSHOWHITS=Show article hits
READ MORE…=Read more…
READ MORE=Read more———————————————-
This topic contains 4 replies, has 2 voices, and was last updated by balgev 13 years, 1 month ago.
