  • kristof10 Friend
    #183799
    I go to folder modules/mod_jabulletin/tmpl/default.php and then I go to line 39:
    [PHP]<?php if (isset($item->date)) : ?>
    – <span><?php echo JHTML::_(‘date’, $item->date, JText::_(‘DATE_FORMAT_LC4’)); ?></span>
    <?php endif; ?>
    [/PHP]
    and I change it DATE_FORMAT_LC4 to DATE_FORMAT_LC2 to show the time of publishing of article but I still have this format:
    13-01-09
    Can anyone help?
    Ja TELINE III V2
    Joomla 2.5.8
    This template overrides this module, you should make changes in file: /templates/ja_teline_iii/html/mod_jabulletin/default.php
    It’s recommended to make any customization in template folder since when you update modules, your customization will not be affected.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 11 years, 10 months ago.
