December 11, 2008 at 3:58 pm #136156
I ave noticed that if you have more than one image in your article, then a thumbnail will not show up in JA Bulletin module, can this be fixed as its pretty frustrating!
thanks
wezAnonymous ModeratorJA Developer
- 2008 times in 1700 posts
December 12, 2008 at 10:00 am #282569Hi atomicplanet,
I have tried to check your issue on my local but could not find it.
Maybe this issue only appears on your website. Could you please send me your live url, admin account via PM so that i could check your issue?1 user says Thank You to JA Developer for this useful post
December 15, 2008 at 8:14 am #282934Hi ,
I have tried to go to your link, which you sent me but could not.
I saw this problem:<blockquote>ERROR
The requested URL could not be retrievedWhile trying to retrieve the URL: http://66.147.242.88/~atomicpl/
The following error was encountered:
* Connection to 66.147.242.88 Failed
The system returned: </blockquote>
December 17, 2008 at 2:43 pm #283239hi thanks for trying, but the link actualy works, is it possible the site was down when you tried?
December 18, 2008 at 6:45 am #283314Hi atomicplanet,
I have checked your articles.
This issue is exist on your website.I think images/resized and its subfolders are not writeable.
Please check again.Rob Hawthorn FriendRob Hawthorn
- 3 times in 1 posts
December 18, 2008 at 5:04 pm #283394<em>@JA Developer 95955 wrote:</em><blockquote>Hi atomicplanet,
Please check again.</blockquote>
JA Developer,
How do you make “images/resized” writeable, I’m having a similar problem with JA Tabs and JA Slideshow.What’s the full path of the “images/resized” folder?
nefar Friendnefar
- December 2007
- 42 times in 1 posts
December 18, 2008 at 5:35 pm #283403Log into your site with your ftp client — find your folder. You should have a setting in your ftp client to set chmod (permissions). Mine I can set by write clicking. You’re probably looking for a setting of 750 but if that doesn’t work you could do 777 (this opens it to everything) If it works then know for sure it’s a permission issue. Developer could tell you what exact setting # is needed
December 18, 2008 at 5:49 pm #283406Hi nefar,
Thanks for replying, so I’ve set the “Resize” folder permissions to “750” as suggested.After I’ve done that and the change’s been made is it just a case of F5’ing the page where my JA slideshow is located and hey presto?
December 18, 2008 at 5:50 pm #283407<em>@nefar 96055 wrote:</em><blockquote>Log into your site with your ftp client — find your folder. You should have a setting in your ftp client to set chmod (permissions). Mine I can set by write clicking. You’re probably looking for a setting of 750 but if that doesn’t work you could do 777 (this opens it to everything) If it works then know for sure it’s a permission issue. Developer could tell you what exact setting # is needed</blockquote>
Hi nefar,
This topic contains 9 replies, has 4 voices, and was last updated by Rob Hawthorn 15 years, 9 months ago.
