  • juanjovv Friend
    #182463
    Hello
    I am looking for about my question, but I do not find any answer help me.
    I need move left and right module positions, from right to left.
    I think I must edit default layout blocks, but I do not understand how blocks need changes, because I can not see any left or right block.
    Sorry, but I can not understand T3 Framework.
    Thank you very much
    TomC Moderator
    #473824
    Here are some suggestions to try . . . .
    To move the column from right to left:
    Within file path –> /plugins/system/jat3/jat3/base-themes/default/css/layout.css
    at/about line 17, you will see the following:
    .column {
    float: left;
    overflow: hidden;
    change as follows . . .
    .column {
    float: right;
    overflow: hidden;
    Styling the column:
    Within file path –> /templates/ja_business/css/layout.css
    at/about line 33, you will see the following:
    .ja-inset2 div.ja-moduletable, .ja-inset2 .div.moduletable, .ja-inset2 div.ja-module, .ja-inset2 div.module {
    margin-left: 40px;
    margin-right: 0;
    modify as follows:
    margin-left: 0;
    margin-right: 40px;
    Let me know if this is the result you were wanting to achieve.
    juanjovv Friend
    #473842
    Works Prefectly
    I thought I could make it through template layouts.
    Thank you very much
    TomC Moderator
    #473844
    Most Welcome … Glad I could be of assistance.
    All the best with your continuing site development !!!
This topic contains 4 replies, has 2 voices, and was last updated by  TomC 12 years, 1 month ago.
