  • cazisconquering Friend
    #206743
    I have a fresh installation. I downloaded JA Charity Quick start and copied folder structure to public_html
    When I access the site to go through installation steps I get the following:
    Fatal error: Uncaught exception ‘RuntimeException’ with message ‘Library path /libraries/cms cannot be found.’ in /home/bravofaces/public_html/libraries/loader.php:293 Stack trace: #0 /home/bravofaces/public_html/libraries/cms.php(30): JLoader::registerPrefix(‘J’, ‘/home/bravoface…’, false, true) #1 /home/bravofaces/public_html/installation/application/framework.php(39): require_once(‘/home/bravoface…’) #2 /home/bravofaces/public_html/installation/application/bootstrap.php(17): require_once(‘/home/bravoface…’) #3 /home/bravofaces/public_html/installation/index.php(21): require_once(‘/home/bravoface…’) #4 {main} thrown in /home/bravofaces/public_html/libraries/loader.php on line 293
    Please help.
    I believe I have php 5.4
    Regards Caroline
    Adam M Moderator
    #572765
    Hi Caroline,
    Look like there was a problem when you uploading files / folders to your site. Please upload the compressed quickstart folder to your site then unzip it there via cPanel >>> File Manager and try again.
This topic contains 2 replies, has 2 voices, and was last updated by  Adam M 9 years, 6 months ago.
