  • amarks56 Friend
    #191459
    If you look at this page, you will notice the css gets messed up on the audio box. I disabled and enabled Ja comment plugin and that was the cause.
    Buttons also don’t work.
    Example on: http://www.drummeral.com/bus-tracks/257-guantanamera
    phong nam Friend
    #509433
    Hi amarks56,
    Thank you for your feedback. I have transfered this issue to our developers for the bug fix in next update of JA Muzic template, you can keep track on work flow at http://pm.joomlart.com/browse/JATCMUZIC-132
    The temporary solution is integrating the Facebook Comments box into Joomla articles by adding the FB comment scripts into 395th line of templatesja_muzichtmlcom_contentarticledefault-track.php file.
    amarks56 Friend
    #509499
    Thanks! When it is resolved, can you help me to apply the solution? Instead of having to reinstall the template. Thanks!
    phong nam Friend
    #509559
    Yes. Off course. There is a jQuery conflict between the JA Muzic template and JA Comment component (Content – JA Comment). Lets wait some time for our developers to check this conflict carefully and update the bug fix or at least an detailed explanation on this case.
This topic contains 4 replies, has 2 voices, and was last updated by  phong nam 11 years, 1 month ago.
