September 18, 2011 at 11:26 am #168682
I just bought jacomment, and i dont have any idea, how can is set Kunena’s avatar, because i just found the gravatar options 🙁
Any help?
Thank you
Sadehoudini Friendhoudini
- August 2011
- 2 times in 3 posts
September 18, 2011 at 12:13 pm #413380<em>@sade 268579 wrote:</em><blockquote>I just bought jacomment, and i dont have any idea, how can is set Kunena’s avatar, because i just found the gravatar options 🙁
Any help?
Thank you
Sade</blockquote>Hi Sade,
Have you tried the following?
1) Login as Administrator
2) Components > JA-Comment
3) Layout > Use Avatar
4) Select Fireboard (kuena)September 18, 2011 at 12:14 pm #413381I only have just GRAVATAR option 🙁
i tried rewrite the avatar image path as it has written in another thread, but it nothing happened 🙁
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
September 18, 2011 at 1:52 pm #413394September 18, 2011 at 1:58 pm #413396ofcoz!
Kunena 1.7
i read the other threads, i should rewrite something in jahelper? if somebody use 1.7, and latest jacomment, please, help me, this function is must have 🙁
- February 2014
September 18, 2011 at 6:14 pm #413454Hi,
I could check this issue (and try to provide some help) for you if you can provide with some temp admin and ftp access on your website.
Manos
- February 2014
September 18, 2011 at 11:20 pm #413505Hi, according to your message (PM) you issue is solved! However for the benefit of the community we will be glad if you share the same solution with us!
Manos
September 19, 2011 at 4:42 pm #413650I dont know, my girlpal fixed it.
She talked about it called bad modul(?), and wrong path. I’m not a programmer, but im happy she could fix it.
she told she copied the UDDEim’s code for avatar part, and worked well.
This is what is count for me.
I hope i will not have problem to next upgrade.AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 3 voices, and was last updated by sade 13 years, 3 months ago.
