  • adplus Friend
    #939060
    When adding Advanced Custom Module to an article page (doesn’t mater which layout or content type or position), Ja Comments seems to go crazy and begins to multiply itself – so that you can see the same comment form ~10-15x times under an article.
    Seems like a conflict in Javascript.
    This makes it impossible to use Ja Comments with at least Teline V template (I do not know if other templates which use ACM also have the same problem?).
    1. ja-comments-acm
    Could you also send us the FTP account so we will have a look?
    adplus Friend
    #940976
    Luna Garden Moderator
    #941026
    I have checked your site and haven’t seen the error as your capture. How replicate this error so we can help you to fix it ?
    adplus Friend
    #944818
    #945418
    Yes, we can see it now. Could you post FTP info of your site(in Private Reply) , so we can look closer to the problem.
    adplus Friend
    #946020
    #946601
    We can’t access to FTP of your site, could you post a link that contains the problem, the previous link you post is not, and what type of ACM module that cause the error
    #946604
    We can’t access the FTP of your site, could you check the info.
    And also, post a link that contains the error, or tell us what type of ACM module that cause the error.
    adplus Friend
    #946975
    adplus Friend
    #946981
    Mo0nlight Moderator
    #947267
    I can’t not access by the ftp account.
    Anyway, you can fix this bug by following this tweak:
    Edit the file /plugins/content/jacomment/jacomment.php
    find this
        //Content_top_ads - Content_bottom_ads
        function displayComment(&$article, $option = 'com_content')
    around line : 468
    Change to :
             $this->html='';
This topic contains 11 replies, has 4 voices, and was last updated by  Mo0nlight 8 years, 5 months ago.
