  • karma1775 Friend
    #186751
    See how the popup is being blocked by the thumbnail of the slideshow? Also by the image in the original slider.
    How can I fix this?
    1. Capture1
    Wayne Friend
    #489862
    maybe can try give this module a class suffix, and make it in custom css file a z-index function.
    karma1775 Friend
    #489961
    <em>@dwnrwsb 368920 wrote:</em><blockquote>maybe can try give this module a class suffix, and make it in custom css file a z-index function.</blockquote>
    I don’t know what that is. Im not an experienced developer. I’ve tried using the no-padding class, and I’ve tried to adjust ordering to see if maybe that changes whats on top. No effect.
    Ninja Lead Moderator
    #490024
    I tried to access your site but it is very slow i could not check anything on your site ( layout is broken because css files are not loaded).
    karma1775 Friend
    #490548
    Is that why it loads slowly? I’ve been throwing support tickets at these guys all over the place because sometimes it loads slowly other times its fine.
    #490704
    It is difficult for me to guess the issue and give out the solution but you can have a look at JA Mitius Template user guide for reference, hope it helps you out.
This topic contains 6 replies, has 3 voices, and was last updated by  Ninja Lead 11 years, 7 months ago.
