  • success_bus Friend
    #185178
    JA Content Slider at the Bottom displays images with low quality compared to original images.
    It is possible to change the quality of images?
    I am using JA Tiris Template for Joomla 3.0
    Best regards
    Sam
    1. slider
    phong nam Friend
    #484363
    Hi success_bus,
    It seems that you are talking about opacity property in JA Content Slider. You can see, when you put your pointer over images, they will display original quality. If you want to customize opacity property, you can go to:templatesja_tiriscsscss3.css, find /* Content Slider —–*/ . Pls inform me if my reply help you !
    Regards,
    Leo
    success_bus Friend
    #484488
    Thanks Leo,
    Problem with the quality of original quality.
    Best regards
    Sam
This topic contains 3 replies, has 2 voices, and was last updated by  success_bus 11 years, 10 months ago.
