February 26, 2010 at 1:41 am #149034
I was to get the CP Panel working in terms of it hiding and it coming down when you click the arrow… But when it drops down, there’s nothing in the black space- no login information… I’ve searched all over the forums. Please help.
Your “how to” on this template is pretty bad. Like the designt, but a real pain to figure out how to get it working and I’ve been using Joomla for 4 years.
iguinee Friendiguinee
- December 2009
- 32 times in 1 posts
February 26, 2010 at 2:41 am #333917is the login form enabled?
Send a url to ur site please.
February 27, 2010 at 1:27 am #334071It is enabled now, but the form sits not in the black top section but instead down. You can see the site here:
The Login Form is Position: ja-cpanel
Thanks for the help. I just don’t know what could be going wrong.
March 1, 2010 at 8:49 am #334183I’m havving the same issue! Please help!
Saguaros ModeratorSaguaros
March 1, 2010 at 10:58 am #334202@johntrippe Pls give me the administrator account and the FTP account via your ticket # NQB-594196 . i try to resolve this issue.
After i resloved this, i ‘ll post my answer for you in here
thanksMarch 1, 2010 at 6:40 pm #334245I’m not comfortable in giving out that kind of access… are there any suggestions you can recommend for me to try?
- December 2009
March 3, 2010 at 12:56 am #334518johntrippe
This guys are best placed to investigate your issues from your Joomla back end.
You must not give login details via this open forum BUT you should PM the details to the person as he appears to be a Joomlart Staff.
If you are still not happy, try to submit another support ticket or wait for more info.
March 3, 2010 at 4:09 am #334568Dear johntrippe !
i found the reason causing this issue, you have a mistake of postion, you put the login module on the “ja-cpanel” position, it ‘s wrong position. Now pls re-put the module on the login position
Good luck
September 23, 2010 at 12:47 am #356425Tienhc,
I am having the same problem. There is no login position in the JA lime template. Please advise. My site is not live yet it is on localhost. Is it possible for you to look and diagnose the problem
adminet Friendadminet
- July 2007
September 30, 2010 at 7:11 pm #357237Agreed. There is no login position on the JA Lime template and your guide clearly states the following:
1/ Install the module via Joomla Installer
2/ Assign module to the position: {ja-cpanel}
3/ Enable the modulePlease advise. thanks.
This topic contains 10 replies, has 6 voices, and was last updated by adminet 14 years, 3 months ago.
